Broke Rear Rubber Fuel something?
Old Dec 6, 2008 | 02:52 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Was doing my steel braided earls 3pc set, doing the rear, there is this plastic ball with a rubber hose going to it attached to the bracket holding the fuel line at the rear center. I broke this off, now its just open rubber hanging, i smelt it, kinda smelt like gas but it was not wet and is not leaking. What is this? and should i replace it? Thanks for any future replys!
I post a pic tomorrow when I change my rear fluid.
Old Dec 6, 2008 | 04:22 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Broke Rear Rubber Fuel something?
Mine isn't a ball, it's more like a small black canister with a white top. This is a remote pressure/vacuum relief valve. It's the only device on my car in that area, but it may not be what you described.
Old Dec 6, 2008 | 12:45 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
that's exactly it !
Is it a safety feature for the gas tank or something ?
Old Dec 6, 2008 | 01:56 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
that's exactly it !
As fuel is drawn out of the tank is allows air in to replace it (while maintaining a slight vacuum). If it just broke free of the mount, but is still in one piece you can probably just tie wrap it up there.
Old Dec 6, 2008 | 04:59 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
the plastic peice itself is broke, crumbled like dust lol
Old Dec 6, 2008 | 05:57 PM
jv9999's Avatar
Engine: 5.7L/350
You can either leave it off (if you don't need to pass emissions and the fumes don't bother you) or buy a new one from GM. Someone on here found the p/n and posted it here a couple months ago.
Old Dec 6, 2008 | 06:33 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
go to gmpartsdirect.com, part number10033125, this should be what your looking for, I bought one about a year ago
Old Dec 6, 2008 | 06:46 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
I live in great old California but i didn't see the emission guy look at that area on his walk around.
Can Fuel come out this line if my tank is crammed fuel of fuel and i turn fast?
In the summer does this relieve the pressure from expansion ?
Just a few questions but i think ill replace it. Thanks for your help!!
Old Dec 6, 2008 | 07:56 PM
jv9999's Avatar
Engine: 5.7L/350
He probably connected a device to your fuel fill though. I'm pretty sure you'll need it to pass CA emissions.
Old Dec 7, 2008 | 02:04 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
For a gas tank pressure check probably
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
AkDrifted
Aug 17, 2015 07:45 PM
