Starter Circuit woes
Old Dec 6, 2008 | 03:22 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Im having some problems with my 94 Trans Am. auto
Long story short, the wire giving the voltage signal to engage the solenoid at the starter is getting 8 volts.
Battery cables are clean and tight. Battery checks at 12.4 volts. At the ignition switch there is 12.4 volts going in, 8 volts coming out.
So I replaced the ignition switch. Same thing with a new switch. I unhook the wire at the starter solenoid, check it unhooked and it has 12.4 volts. Go back to the ignition switch and there is 12.4 volts coming out of it. Hook the wire back to the starter, check again and 8 volts.
If you jump the starter at the starter, it will crank just fine.
What is happing? Solenoid bad?
Old Dec 6, 2008 | 07:29 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Re: Starter Circuit woes
You pretty much eliminated anything else.
Old Dec 6, 2008 | 07:34 PM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
Battery?
Just because battery shows 12volts doesnt mean its good. If it works when you jump it, then its possibly the battery.
Old Dec 6, 2008 | 08:54 PM
3rdgenmaro's Avatar
Car: 88 IROC
Originally Posted by rallysport383
Battery?
I mean jump the wires at the starter. Not using jumper cables or anything, but by taking a screwdriver across the terminals at the starter.
I ordered a solenoid today. I will let everyone know if that fixed it.
What sucks is that it is a brand new starter
$750 L98
Feb 1, 2025 02:25 PM
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
