oil leak
Old Dec 8, 2008 | 10:49 AM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
oil leak
had a tranny leak a few weeks ago from the speedo cable mount and now the wet spot under my car is back. i put her up on jack stands and noticed it dripping from on top around where the tranny meets the motor kinda in the same spot where the oil filter is. i wanted to know if anyone knows what part of the engine has oil flowing through it that might leak.
Old Dec 8, 2008 | 12:05 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: oil leak
Sorry, but that sounds like the front seal is leaking. The trans has to come out to replace it (hence the sorry part).
Old Dec 8, 2008 | 12:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it's dripping from on top, that's not a transmission front seal leak.
The valve cover and intake manifold are known leakers from up there. Also the oil pressure sending unit, if it's behind the intake manifold.
Old Dec 8, 2008 | 12:55 PM
jv9999's Avatar
Engine: 5.7L/350
Re: oil leak
I assumed it was transmission fluid (red). If it's oil, these are the prime candidates.
Old Dec 8, 2008 | 09:05 PM
Car: 87 Camaro
Engine: 5.7 350 TPI
Re: oil leak
the tranny leak was back where the speedometer cable screws onto the tranny because the threads were ruined. fixed that with new speedo cable. it is an oil leak because i had to add more oil recently and its black not red. it could be the oil pressure sending unit because today when i took it for a ride the oil gauge was reading a lower number than usual. the needle sits around 30 at idle and today it read lower 20s which it has never gone. ill try to locate a more exact location and post where its coming from but it is coming from up high in the engine compartment.
Old Dec 9, 2008 | 12:25 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: oil leak
speedo cable on a 87????????
Old Dec 9, 2008 | 01:08 PM
Car: 87 Camaro
Engine: 5.7 350 TPI
Re: oil leak
running a 350 tpi with 5sp manual transmission. 87 irocs with a 350 were not made with a 5sp tranny. swapped out auto for manual in this car no point in having a sports car with an automatic takes the thrill out of driving it
Old Dec 9, 2008 | 01:56 PM
jv9999's Avatar
Engine: 5.7L/350
Re: oil leak
Yep. Only FB's got electronic speedos in '87
Old Dec 9, 2008 | 02:08 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: oil leak
Camaros used cable driven speedometers from '82-89. Firebirds got electronic speedometers in '86 but the idiot light clusters continued to use the cable drive.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
