s10 manual steering box
Old Dec 9, 2008 | 05:37 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
will this one work??? I know it says it will but i have herd there is 2 differnent steering boxes for the s10 and one of them wont work ???http://cgi.ebay.com/ebaymotors/Manua...Q5fAccessories
Old Dec 9, 2008 | 08:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: s10 manual steering box
That's the 4 bolt top cover model. It's a direct bolt in however you should use the third gen pitman arm. It's a slightly different length than the S10 pitman arm. Not enough to cause a problem but it will change the steering geometry slightly.
Everything else will bolt right up. Usually someone wanting a manual steering box will purchase the wrong one. The older versions with the 3 bolt top cover will work but need a few modifications because the sector shaft that the pitman arm attaches to is the wrong size.
Old Dec 10, 2008 | 08:11 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
thank you
Old Dec 10, 2008 | 08:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The only other thing to watch out for is the sway bar. If its a track only car, its not an issue as you wont need the sway bar. If your using it on the street or you want the sway bar for some reason, you will need to mod the D/S mount. It requires some minor cutting/welding to get it to bolt up.
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
