Odd Spark Plug Wire Issue, Won't read near distributor??
Old Dec 10, 2008 | 09:09 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I've been chasing an idle issue ghost and ran into something that I've never come across. After replacing my MAF relays, CTS, and cleaning the MAF sensor itself; the L98 didn't want to fire on all cylinders initially. I took my timing light to test each wire for consistant firing spark. On the passenger side all four New Taylor wires worked as expected, but when I went to test the plug wires on the drivers side, I could't get my light to flash. I hooked it up to number 1 near the spark plug and got a correct flashing, but as I went back up the wires nearer the distributor, I couldn't get the timing light to read.
I know that I'm getting a strong spark off the new distributor cap, as my wife watched me body slam across the front fender like a dolphin when the MSD spark box bit hard! Wow, I've never felt an ignition kick like that before! It was like going from coolaid to triple expresso!!
So why wouldn't I be getting a timing light reading on the driver's side plug wires. Every thing is new and improved on this. Nitro-Nicky
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
djmarch
Aug 9, 2015 05:27 PM
