Brake problem & new engine swap running rough
Old Dec 15, 2008 | 08:52 AM
System1's Avatar
Car: 1988 iroc camaro
Engine: forged 383 tpi
Whats Going on guys, heres the problem. I just swapped my 88 Iroc 5.7 350 for a 383. I retained the stock intake for now. Heres all the info ECM:1227165 Code:ABYA, Compression:10.5:1, old style Heads:Cast Iron with 110lsa, Intake:290/300 Exhaust:222/230 @.050, Lift:.499/.512 with 1.6 roller rockers, Block:ZZ4 crate motor. Anyways sorry for all that just thought it would help. Back to the problems, The brakes seem to have no response as far as being power brakes. I can stop, but it is like the car is not cranked (how the brakes feel when thrown into neutral with out cranking). Second problem, when driving the car has a major loss of power, and doesn't shift very well. The Fuel pump has been upgraded as well as 30lbs fuel injectors. Psi is set to 45 and timing is correct. Any help would be appreciated.
Old Dec 15, 2008 | 11:52 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: Brake problem & new engine swap running rough
Sounds like you have a vacume leak somewhere. Check to make sure all the vacume hoses are connected and any unused vacume ports are plugged off.
Old Dec 15, 2008 | 05:03 PM
System1's Avatar
What type of vacuum ports are unused, Thank you for your help.
Old Dec 15, 2008 | 05:52 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Check the vacuum line going to the brake booster also.
Old Dec 15, 2008 | 06:03 PM
vbMike's Avatar
I couldn't tell ya, you did the engine swap. If it's carbed, I think sometimes there are unused ports on the carb that need to be plugged.
Old Dec 16, 2008 | 08:05 AM
System1's Avatar
It is fuel injected. My shop manual point to a vacuum leak too. Guess the search is on. I was having the problem before i did the swap though. Is there a way to increase your vacuum if your engine is not producing enough? (maybe a dumb question) Thanks again guys.
Old Dec 16, 2008 | 11:47 AM
vbMike's Avatar
It's common for power brakes to now work well at idle if you put in a big cam because it doesn't produce enough vacume but they should work fine as the RPM's increase. You can replace your vacume canister with a larger one or add in a second one.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
