GMPP Crate Engine check list
Old Dec 15, 2008 | 09:01 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Hi all. I've got a zz383 sitting in its crate waiting to go into my '83 camaro and was wondering what is done to these engines before they are shipped? Does GM actually run-test them? .
What sensible things do I need to do before first starting it?
What do I need to consider in terms of a 'break-in' period?
Thanks,
Jon
JSD MOD 12/15/08
Old Dec 15, 2008 | 09:39 PM
Damon's Avatar
Re: GMPP Crate Engine check list
You don't need to do much. Remember to prime the oiling system before you turn the key the first time- dry starts are very bad.
It's a roller cam motor so there is no cam break-in period.
I always change the oil/filter very soon after firing it up the first time. There's always some dirt & debris in a fresh built motor and you want to get that OUT of the motor quickly. I often do it with less than an hour of run time on a fresh engine.
I avoid WOT and very high RPMs for about the first 100 miles (not babying it, just not wringing it out all the way) then I let 'er eat after that.
Old Dec 16, 2008 | 09:40 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you put some bucks to get that. enjoy - im sure you will.
Old Dec 17, 2008 | 09:10 PM
Car: '83 Berlinetta
Engine: 383 CI
Thanks guys.
Jon
italiano67
Dec 11, 2016 09:21 AM
masonta
Aug 31, 2015 10:14 PM
Linson
Aug 21, 2015 02:12 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
