Combo Help...
Old Dec 19, 2008 | 11:03 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Combo Help...
Hey guys, I have an 89 IROC with an 86 LB9, I already put a cam in it 420/442, its getting 1.6 rollers which will bump those numbers to 448/472, a custom PCM For Less chip, and 3.42's. My plan for the future is a mild 355 or 383 and I want to put things that will benefit the 305 but be able to transfer over to the swap. I know this has been beaten into the ground but I want heads that will work on the 305 as well as what ever I build. I was looking at http://store.summitracing.com/partde...5&autoview=sku
They have a 56cc chambers I believe my 416's have 58, so my CR would jump up a little(anyone know what?), and 1.94's. My question is with a complete gasket match from the heads to the plenum with high flow runners will they perfrom well? Or am I better of having my 416's cut for 1.94's and ported? My next question is will those TF heads be able to support around 380-400hp with a good port and the 1.94's? I really wanted to go 2.02's but I know they will not fit the 305. I just want to see what I can do with the 305 while the new motor gets built. Sorry for the long post, any info is appreciated. Thanks, James.
Old Dec 21, 2008 | 02:50 PM
Car: '89 IROC-Z
Engine: LSx
Re: Combo Help...
ttt
Old Dec 21, 2008 | 05:16 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Combo Help...
Yes the TFS small chamber 305 heads will work very well on your 305 and will transfer well onto a future 350 or 383 as long as you keep the "high torque" concept.
You don't need a 2.02" valve for that.
The 170cc ports flow enough to support well over 400hp on a 350 or 383.
Simular to the idea of the Edelbrock ETEC 170 but with a small chamber and a conventional SBC port height.
Old Dec 21, 2008 | 06:06 PM
Car: '89 IROC-Z
Engine: LSx
Re: Combo Help...
Thanks for the info, does anyknow what the 56cc chambers will put my CR at?
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Zane Story
Oct 8, 2015 12:40 PM
roysatikas
Sep 22, 2015 08:15 PM
R13_Braz
Sep 18, 2015 05:00 PM
