did my car die?
Old Dec 18, 2008 | 10:51 PM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
did my car die?
i just posted something about my blower motor, and i went to autozone to order the part. came outside and started my car ( the car was running and idleing perfectly before hand) floored the pettal cuz their was some water on the floor proceeded to drive off and the car started sputtering and wouldnt go fast than like 3 mph, put the car in park and gave the engine some gas and i didnt hear any knocking or clanking, all my wires are new and just replaced. now the car is idling horribly and stalls when driving a phew feet, im not getting any computer codes either.
Old Dec 19, 2008 | 02:03 AM
fychelio's Avatar
Axle/Gears: ????
problem idling and driving..stalls out
what damage can turning on your car and immediatly flooring the gas pedal cause? can it blow something in the msd?
Old Dec 19, 2008 | 05:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can ventilate your crankcase - with a connecting rod. . .
The main problem it causes is wear due to the oil not lubricating properly because it's not up to operating temperature. The chances of it causing an ignition problem are remote.
Most likely you hurt a valve - spring, lifter, valve seat, retainer, guide, cam lobe, etc.
Old Dec 20, 2008 | 05:32 PM
fychelio's Avatar
Axle/Gears: ????
Re: did my car die?
well my car was running perfectly and all the sudden i do that and it doesnt idle properly and when u try to drive it doesnt hardly move, and wants to die, but their doesnt seem to be any oil on the spark plugs. and all the cables are new and i just changed the ignition control module.
Old Dec 21, 2008 | 12:55 AM
kcb37's Avatar
Re: did my car die?
I think before I assumed it was done, I would start checking the simple stuff.
Plugs, wires, cap, rotor, fuel filter, fuel pump, timing.
Sounds kinda like my fuel pump.
It worked great one day, then it would stall or almost stall my car, only way I could move it was slipping the clutch, (interesting in the middle of an intersection) Then a few minutes later it would be fine for the day. Till it finally just quit altogether.
Old Dec 21, 2008 | 01:01 PM
fychelio's Avatar
Axle/Gears: ????
Re: did my car die?
yea, sounds better then wasting it, i changed all plugs and cables. even the ign. module, imma try the fuel pump. today, i noticed one thing... when you try to hold the acceleration down and keep it idle at 2000 rpms in park no matter how much u hit the gas itll just start going down and if you try to floor it itll shutthe car off
Old Dec 21, 2008 | 02:50 PM
88sleeper's Avatar
Car: 88 Z28
Re: did my car die?
Why would water on the (I'm Assuming) floorboard cause you to floor the accelerator?
Does your car eventually die in park as well?
It might be an exhaust problem. I had an 88 Camaro that was driven through a deep puddle of water that touched the exhaust and because of poor factory metallurgy the inside of the exhaust crimped while the outside appeared to be fine.
This doesn't explain the high idle, but would explain the WOT engine stall.
Old Dec 21, 2008 | 08:33 PM
fychelio's Avatar
Axle/Gears: ????
Re: did my car die?
not the floor board, their was water on the floor so i burned out. and than this crap happened
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
