85 camaro problems!!!!!Help!!!!!
Old Dec 23, 2008 | 11:23 PM
Dime333's Avatar
Car: 1985 Camaro Z28
Engine: 305 5.0L (LB9)
Transmission: 700R-4
Axle/Gears: No idea
my 1985 Camaro Z28 started shooting oil out of the dipstick a couple days ago. i changed the oil and now the oil pressure is over 60 psi!. when you rev the engine the oil pressure drops to about 40 psi the pops back up. when i did my oil change really thick oil came out. The car has a 5.0 TPI.
Engine sludge?
Oil pump?
Old Dec 24, 2008 | 08:38 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 85 camaro problems!!!!!Help!!!!!
cars that have sat for long periods can/will build up eng. sludge . change PCV valve , flush eng. & all breather lines . if you can , remove valve covers ( disc. battery first ) and make sure drain holes on lwr. front & rear of heads are clear first . a good enema/flush of the oil system can do wonders . good luck .
Old Dec 24, 2008 | 11:23 AM
danandamy's Avatar
Car: 86 Camaro
Oil shooting out the dipstick? The only time I've ever had an engine do that, i had a whole in a piston and all the compression from that cyl was going into the crankcase.
Dan
Old Dec 24, 2008 | 04:41 PM
Dime333's Avatar
Axle/Gears: No idea
I flushed the engine 2 times, changed the PCV valve and the pressure is still high. for some reason it wont stop high idleing at about 2500 rpm. any ideas?
92camaroJoe
Jul 29, 2023 07:57 PM
TheJoeY88
Dec 31, 2016 07:30 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
