poping noise while turning
Old Dec 24, 2008 | 03:06 AM
selmahotrod's Avatar
Car: !990 Camaro IROC Z
Engine: 5.7 L
Axle/Gears: !0 Bolt- 3.42 Posi- Disc
I get a noise when turning from the front- 1990 IROC. need help!
Old Dec 24, 2008 | 03:36 AM
Twin_Turbo's Avatar
Re: poping noise while turning
Is it a single pop or when rolling does it keep popping when turning?
If a single pop, check the steering linkage, if it's going pop pop pop when turning check your wheel ebarings and wheel studs, siometimes a loose lug nut can cause that too.
Old Dec 24, 2008 | 03:45 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
My mom's subaru and my dad's Z28 both have this as well... Have yet to really look into it though... Post up if you are able to find the source...
Old Dec 24, 2008 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. A search always provides a wealth of info. Balljoint perhaps.
JamesC
Old Dec 24, 2008 | 07:19 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
My '99 S-10 was making that yype of noise back in November. when I had to replace my rotors I found the cause (at this time it wasn't making noise.) The right upper control arm bushings were worn. The firewall bushing was the one making the noise there was a washer missing that goes on before the bushing probably cracked and broke off. Unfortunately they're not included with the bushings they only comes in a control arm repair kit. The truck will have to wait till I have time to go to A pull-A-Part salvage.
Old Dec 24, 2008 | 06:14 PM
Engine: 5.7 L
All front end parts are tight. I dont know!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Randomtask2
Sep 7, 2015 05:06 PM
