results after battery relocation
Old Dec 28, 2008 | 02:46 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Ive ben toying with the idea of relocating my battery to the trunk for some better weight transfer. I want some experiencies from people who have done this and saw/or didnt see improvements. Basically what I'm trying to get at, is if it is worth it or not. Thanks
Old Dec 28, 2008 | 08:48 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Re: results after battery relocation
The relocation will not net you anything noticeable at the track. It is however a great way to make more room in the engine bay if needed. IMO there are easier ways to pick up the small amount of time it may or may not gain you.
If you relocate to the trunk and you run your car at the track check with local track rules. I moved my battery back up front to pass tech because the local track runs by NHRA requirements. That means an external cut off switch on the back of the car(in the bumper or tail lights) and a battery box. I just couldn't put a hole in a set of 91-92 TA tail lights or a hole in the bumper either.
Old Dec 28, 2008 | 03:25 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i put mine in the back for a bit better balance and to clean the bay up - only draw back is ruining new wires drilling wholes and at least for me reconfiguring a new wiring block
drumstixer
Sep 29, 2015 03:02 PM
z28joe2
Sep 28, 2015 05:54 PM
ndndndnd
Sep 28, 2015 08:00 AM
JSDaddy189
Sep 26, 2015 03:50 PM
lanceflame44
Sep 25, 2015 12:28 PM
