Electric pump help
Old Jan 2, 2009 | 10:04 AM
TazCowboy's Avatar
Car: 1991 Camaro RS
Engine: 350 SBC
Electric pump help
I cant seem to get the manual pump to work so I got a in-line electric pump its a airtex master #E8012S and it says should be wired to oil press switch. So how do I do this since not using ECM?
Old Jan 2, 2009 | 01:04 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Electric pump help
Do you still have the fuel pump relay? What year/model is the car?
Old Jan 2, 2009 | 03:46 PM
TazCowboy's Avatar
Car: 1991 Camaro RS
Engine: 350 SBC
Its a 1991 camaro RS that had the 3.1V6 FI. I put in a chevy 350 4bolt main with a holley 600. I removed the in tank fuel pump and extended the pick up tube on the sending unit. I also removed the canister line and plugged the line on the sending unit for that and the return that I am not using. So besides running the fuel line to the manual pump thats all I have done to it.
Old Jan 3, 2009 | 12:31 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
take the grn/wht wire, or wahtever wire is connected to the "C" terminal of the fuel pump relay and connect it to the pink ignition wire, or whatever wire is hot only in the run/start key position. Then connect your pump to the hot wire that powered the in tank pump. The relay will work in parallel with the oil pump switch which is already connected to the fuel pump circuit.
Old Jan 3, 2009 | 03:40 PM
TazCowboy's Avatar
Car: 1991 Camaro RS
Engine: 350 SBC
Thank You Very Much for the info.
Old Jan 4, 2009 | 12:53 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
This engine hasn't seen fire in the holes yet, right?
Old Jan 4, 2009 | 01:37 AM
TazCowboy's Avatar
Car: 1991 Camaro RS
Engine: 350 SBC
Not exactly it hasnt. I did pour some gas into the carb hoping that would help it but it didnt. All it did was tease me. LOL
Old Jan 4, 2009 | 02:37 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Keep me posted, or PM, would like to hear it running!
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
