Engine shut off in traffic
Old Jan 2, 2009 | 01:35 PM
libolt's Avatar
Car: 1991 Trans Am
Hi,
I was driving my '91 Trans Am to work today when it shut off on me. I was sitting in traffic at a light and when I hit the accelerator, it shut off and the SES light came on. I was able to put it in park and start the car back up. Drove it the rest of the way (about 2 miles) without issues. So when I got to work I did some research on here and figured out how to do the paperclip test. The only error code it's giving is the standard error 12. I replaced the ignition control module and a bad wire about a year and a half ago and that was the last time I had any issues with the engine shutting off while driving.
The engine is a 305 TPI with 700R4 transmission.
Any help is greatly appreciated.
Old Jan 2, 2009 | 02:47 PM
88_thirdgen's Avatar
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
Re: Engine shut off in traffic
Originally Posted by libolt
Hi,
that happen to me once in my camaro...... i changed the IAC valve and TPS sensor and it was fine........ how is it that you do the paper clip test?
Old Jan 2, 2009 | 02:59 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Sounds like your ignition control module again bud, i went through 3 in 6 months.
Old Jan 3, 2009 | 12:32 AM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Cleaned the throttle body lately? It gets carboned up and can cause it to choke off at idle. Just spray it out with carb cleaner. I do mine every spring.
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
