Pulling 305 TBI than building it
Old Jan 3, 2009 | 02:14 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
I have running out of room at my house I figured I could pull it now, figure out how to build motors and such than go from there. I am going to disconnect the wiring harness take out the A/C. Do I need to take out the distributor or anything to clear the firewall when I pull it out? How would I unbolt the transmission so I could pull that out the same time. I might take off the heads, intake and carb because my friend and I would be pulling it out with a long metal bar and chain.
-Are there any articles for building a 305?
Old Jan 3, 2009 | 02:21 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
Re: Pulling 305 TBI than building it
i've heard of people just taking off the cap but i would go ahead and pull the dizzy out to prevent it from getting broke....... as far as the tranny take off drive shaft , torque arm, shift cable, electrical connectors and cooling lines then unbolt cross member
Old Jan 3, 2009 | 02:30 PM
robster66's Avatar
Engine: 305 T.B.I.
Sounds like a plannn, last time I pulled the motor I was probably 16 and it was a 2.8 that we just lifted out and threw. It was a school night and there were 10 people and my car at friends garage and we were drinking that was insane.
Old Jan 3, 2009 | 04:35 PM
robster66's Avatar
Engine: 305 T.B.I.
This is whats done so far, everything I do I like to just keep posting to keep track of myself. I also am working on my main car right now.
-Removed stock air cleaner
-Removed Fan
-Disconnected A/C lines
-Removed Radiator
-Removed Water Pump + Hoses
-Disconnected most of wiring harness
-Removed Ignition Coil
Than it got dark instantly and couldn't see =/
Old Jan 3, 2009 | 11:35 PM
robster66's Avatar
Engine: 305 T.B.I.
If I ever get this done and swap the motor I plan to have A/C, smog pump, egr, and a.i.r. removed. What would I have to do to have this? I looked at some motors and do not even see a a/c delete pulley. I probably also will swap T.B.I. for TPI and remove cruise control
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
