old school engine with TPI system?
Old Jan 3, 2009 | 07:14 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
is there a way to make an old school motor work the TPI system...i know edelbrock makes a retro manifold(my car is current TPI)..but im talking about all the computer/sensors/ the distrubiter and all that jazz please give me some advice thx
Old Jan 3, 2009 | 07:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: old school engine with TPI system?
Just bolt it all on and wire it all up. The engines are the same, TPI or not.
Old Jan 3, 2009 | 08:15 PM
1985WS6TA's Avatar
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
Any small block chevy from 283 C.I. to 400 C.I. will accept a TPI setup. The only thing that matters is the heads.
The only important thing to know is if you have 1987-up cylinder heads which have valve covers with 4 bolts in the center or if you have pre-1986 cylinder heads which have valve covers with 2 bolts on each side.
The difference between the heads is the bolt pattern on the intake.
So the pre-1986 heads will accept a 1985-1986 TPI
and 1987-up heads will accept 1987-1992 TPI
Old Jan 3, 2009 | 08:37 PM
RedHawkLB9's Avatar
Car: 89 Formy
Transmission: A4
ok good...but what about the distribiters
can i use my current set up with remote coil(roller cam dist)..or do i need an old school HEI dist
Old Jan 3, 2009 | 08:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use the TPI distributor.
Old Jan 3, 2009 | 08:50 PM
1985WS6TA's Avatar
Engine: 355 TPI N/A
Axle/Gears: 3:42
any small block chevy distributor will work but yeah I would definately use the stock TPI Dist. just cuz it came with the TPI, the cam doesnt make a difference.
Old Jan 3, 2009 | 10:00 PM
Vader's Avatar
How old are you talking?
As long as it isn't a '55 with no oil filter boss on the block, it will work.
If the TPI is from a 1989 or older Corvette, it will fit older heads.
MustangBeater20
Oct 29, 2022 09:20 PM
Caspar
Jun 19, 2016 11:19 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
