? about coil for 85 Z28
Old Jan 3, 2009 | 07:15 PM
Chaos2084's Avatar
I am putting in a 350 in my Z28 going non ccc and was wondering what coil I should get? any part numbers? I am pulling the computer out. probably get it done this weekend.
Old Jan 3, 2009 | 07:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ? about coil for 85 Z28
A stock or stock replacement coil should be fine.
Old Jan 3, 2009 | 10:31 PM
Chaos2084's Avatar
where is it at anyways? I had the stock disty in. I am using the old disty from the 350 and using a non-ccc and deleting the computer. Is the coil built into the Disty? Usually there is 9 wires on the disty from what have seen before. 8 for spark plugs and one in the middle that goes to the coil or ignition not sure. There is no plug on the top just for spark plugs.
Just something I have little information about. And was told I needed a new coil if I was taking out my computer and running it caveman style.
Old Jan 3, 2009 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it's a large-cap distributor (all the non-CCC factory ones are), it's under the cover on the top of the cap.
Old Jan 3, 2009 | 10:49 PM
Chaos2084's Avatar
Ok. Is there anything else that will affect the computer not being in there anymore or anything else I will have to change from changing from cc to non-cc?
Old Jan 3, 2009 | 11:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not as long as you've got a manual transmission.
MM2Robinson
Oct 1, 2017 09:16 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
