LT1 composite valve covers & 1.6 rockers....
Old Jan 5, 2009 | 02:15 PM
F-body-fan's Avatar
Hi Guys, I have a set of Corvette LT1 composite valve covers, & am running the GM performance 1.6 roller rockers. They fit fine und the stock ZZ4 steel covers, But no such luck with the composites. These new composites have oil deflectors that appear to be hitting the rockers. Thinking about grinding them off, but wanted to see what everyone else here thinks.
I can post pictures later if that would help.
Thanks, Carl
Old Jan 5, 2009 | 05:26 PM
F-body-fan's Avatar
Re: LT1 composite valve covers & 1.6 rockers....
Here some pictures. I am guessing cutting the oil deflectors off will give me the clearance I need for the rockers, But I am not certain & I think it will be close. Did the LT4 covers have the deflectors? I thoughts LT4's had rollers too? Maybe not?
Attached Thumbnails LT1 composite valve covers & 1.6 rockers....-img_2067.jpg   LT1 composite valve covers & 1.6 rockers....-img_2066.jpg
Old Jan 6, 2009 | 12:52 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I think the LT1 and LT4 corvettes used valve covers that looked the same, but the LT4 valve covers, since they used Crane 1.6 roller rockers, had a set with no drippers on the inside. You can just grind them off and then they should be basically the same as the LT4 stuff.
Old Jan 6, 2009 | 07:31 AM
F-body-fan's Avatar
Thanks, I'll buzz them off!
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 8, 2015 01:18 AM
