engine tapping
Old Jan 6, 2009 | 11:47 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
engine tapping
i just installed a electric fuel pump, and blocked off my mechanical pump. now it has a tick or tapping noise. i removed the pushrod for pump and everything. any insite on it?
Old Jan 7, 2009 | 12:59 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: engine tapping
how well did you mount the pump?
Idk, the I've heard of cams warping before, maybe the pressure on the cam from the pump was keeping the cam from tapping.
Old Jan 7, 2009 | 11:52 AM
Engine: 355
Re: engine tapping
the pump was mounted correctky... dunno y it taps
Old Jan 7, 2009 | 07:22 PM
Engine: 355
Re: engine tapping
anybody else have this problem?
Old Jan 9, 2009 | 01:29 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: engine tapping
find out where the noise is coming from first, you can even use a stick by your ear to help locate if you do not have a stethoscope.
Does it run any different?
Always look at the last thing you did b4 the change occured.
Old Jan 9, 2009 | 09:26 PM
Engine: 355
Re: engine tapping
im thinking it my oil level, its way low so that might be why
Old Jan 15, 2009 | 03:19 PM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
Re: engine tapping
Did you find out what was going on? I am getting a tapping sound from the engine when I reach high RPM.
Old Jan 15, 2009 | 04:20 PM
RobSS1113's Avatar
Re: engine tapping
do what used car sales men do ... Put some thick @ss oil weight in the motor and it should quite it down. It will still be there though. damn those used car guys !!
Old Jan 15, 2009 | 11:46 PM
Engine: 355
Re: engine tapping
i havent messed with it latelym too dam cold... i have a really low level of oil on my dipstick so im leaning toward low oil level
Old Jan 16, 2009 | 12:45 AM
ericjon262's Avatar
Re: engine tapping
I've ran a smallblock without oil on the stick at all(oops) no ticking or tapping til I spun a rod bearing and the piston started slapping the head.
Old Jan 16, 2009 | 12:49 PM
Engine: 355
Re: engine tapping
it only stared making a tapping noise when removed the mechanical fuel pump.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
