runs decient at 50* advanced?
Old Jan 7, 2009 | 02:56 PM
90poc's Avatar
Car: 1990 Firebird
Engine: '89 cubevan 350
Axle/Gears: 98SS 3.42
i have a '90 firebird 5 speed, i replaced the 305 with a 350 from a '89 chev cube van (ran on propane).
350 stuff im using: engine, knock sencor,
305 stuff im using: ecm '746, prom APTY, throttlebody,injectors, iac,tps ect...(pretty much everything!)
it runs and has power but about 1 min after i start the idal starts to increase and decrease in a rythum 1000 rpm - 400 rpm roughly. after about 10 mins it seems to idal fine at 800ish rpm. it has done this since i put it all toghther (a few months). im stoked that i got it going but want it to run right! i got a timing light on it and cheaked it with the wire unhooked and it reads 50* advanced? some say i need prom, esc and injectors and some dont! ive spent hours online and hasseled many parts guys and dealers and hope you can help. please give imput if you have experience that can help me!
Old Jan 7, 2009 | 04:16 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
HUNTING FOR THE PROBLEM
The two most common causes for your problem is:
Oxygen sensor, throttle position sensor.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jan 7, 2009 | 04:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which damper do you have on the 350?
Old Jan 7, 2009 | 05:07 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: runs decient at 50* advanced?
stock fuel pump ??? What psi are you running !
Nina your posts always make my eyes go ,>.<, nice colors
and she ? or he srry if im wrong, is got good suggestions!
Old Jan 7, 2009 | 06:08 PM
90poc's Avatar
Car: 1990 Firebird
thanks,
do i need tps for 350 cause parts guy says 350'S were multiport and im tbi.
yes, stock fuel pump. i dont know how to cheak pressure. i seemed to drive pretty good. does that mean my pressure is ok?
i had the 8'' on (was on the engine when i pulled it from the cube van) after some research i put on the 6''. The timing mark IS right i cheaked this morning. i changed it cause of a vibration. turns out it was a missing ps pump bolt which one should i use. (fylwheel is fron 305 as is the 6'' balancer)
Old Jan 7, 2009 | 10:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by 90poc
do i need tps for 350 cause parts guy says 350'S were multiport and im tbi.)
No, if its functioning properly a 305 and 350 TPS are identical. If you need to source 350 TBI parts for your ride, look at the same year Caprice 9C1 cop car. Injectors are 61# rather than 55#, Knock sensor is different, and finally the chip is way different.
If you have a 6" 305 harmonic balancer and a 350 timing chain cover for an 8" harmonic balancer, the mark is in the WRONG location. Put the correct 8" balancer on it and you should be able to correctly set your timing. FWIW, I run the 6" 305 balancer and timing cover on my 350.
Old Jan 7, 2009 | 11:49 PM
five7kid's Avatar
That's what I was getting to. It's not 6" vs. 8", or 305 vs. 350, but where the timing mark is on the damper ring.
Old Jan 8, 2009 | 03:50 PM
90poc's Avatar
Car: 1990 Firebird
good call! i cheacked the timing mark by finding TDC on intake stroke and sticking a piece of wire in their to feel if the piston was at the top. the 6" seemed to be the same, so much for short cuts! i took it off and "guess what?" the marks are way different! so i reunited the 8" with its origional tc cover and had no problems finding base timing 0* with the wire unplugged!
their was never an"ses" light on (comes on briefly when starting so i know it works) so i figure oth o2 is ok. is that right? however i did decide to mess with the tps and it read .78v so after breaking one of the bolts and loosening the other i removed some of the plastic around the mounting holes and bolted it back on with only one bolt (which made it easier to adjust) and set it to .54v . car now runs without worring me! thank you!
any ideas on how to get the broken bolt out? theirs about an 1\8" sticking out of the tb
and does anyone know a p# for an adjustable tps? mine works for now but messed it up pretty good with the drill!
Old Jan 8, 2009 | 04:25 PM
five7kid's Avatar
"50 degrees" was the clue. The difference between 12 o'clock and 1:30-ish is about 45 degrees.
jhawkeye
May 25, 2022 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
midias
Aug 15, 2015 05:07 PM
armybyrd
Aug 10, 2015 09:23 PM
marcusaw
Aug 10, 2015 08:13 AM
