Is it a LT1
Old Jan 10, 2009 | 09:27 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Is it a LT1
I have a engine that it was supposed to be 89 from the previous owner but i took it to the shop and they told me it's a 98 and up do you guys think it's a LT1 or what could it be it has a TPI though.
Old Jan 10, 2009 | 09:39 PM
Stephen's Avatar
Car: 87 GTA
Re: Is it a LT1
If your shop looks at a TPI engine & says it if 98-up....
Simple...L98 vs LT1...Distributor or not? But the TPI runners perrty much tell the story already. Got a pic?
Run away & never step foot in there again. They are obviously too stupid to even be touching engines.
Old Jan 10, 2009 | 10:07 PM
hotrod7687's Avatar
Car: '91 Camaro, 90 Formula
Engine: 355 carb, 305 TPI
Transmission: TH 350, 700R4
Re: Is it a LT1
If its a 98-up then it would be an LS1 style engine as 97 was the last year for the LT1. Nothing from a TPI would even bolt to a 98-up motor.
Hopefully not all the people in that shop are that dumb, but yea I would never go near that place again.
Old Jan 10, 2009 | 10:13 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Is it a LT1
They said it was 98 from looking at the crank do you know how to check what year the engine are
Old Jan 10, 2009 | 10:21 PM
hotrod7687's Avatar
Re: Is it a LT1
The best way is to get the block ID numbers and run it.
You should be able to find the numbers on the rear of the block, just behind where the drivers side head is bolted. Might have to wipe it down if theres alot of build up of grease, dirt, etc.
If you get the # I can run it for you.
Old Jan 10, 2009 | 10:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is it a LT1
That could only mean at most that the crank is from 1998.
Old Jan 11, 2009 | 03:00 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Is it a LT1
Even then it would have had to be a 1998 L30 or L31 truck engine as all the cars went LS1 by 98.
Old Jan 11, 2009 | 03:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Is it a LT1
Or it's a replacement.
Old Jan 11, 2009 | 03:46 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Is it a LT1
The # is V0727SNA
Old Jan 11, 2009 | 04:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Is it a LT1
L98:
LT1:
Old Jan 12, 2009 | 12:14 AM
Renntek08's Avatar
Re: Is it a LT1
I'm with Stephen. I recently worked on my brothers 89' Z-28 TPI engine. Also owned and worked on 96' Z-28 LT-1 and 01' Vette LS-1 engine set ups. If your mechanic can't tell the difference between these three engines, he's got way more problems than all of us combined. LS series engines are in no way, even loosely related to previouse small block designs.
Old Jan 12, 2009 | 05:24 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Is it a LT1
I found my answer hotrod7687 search by the # and it is from 89 to 96
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
