GLOWING HEADERS AT IDLE
Old Jan 11, 2009 | 08:37 PM
creese187's Avatar
ok, my stainless steel-ceramic coated headers are glowing at idle, i have a 25 degrees of timing at idle, (due to the aggresive camshaft) and an A/F ration of 14:1, from a cold start it takes about 20 minutes or better for them to heat up and glow, i have a brand new engine, heres what it has listed below:
ANY SUGGESTIONS??
383 small block 4 bolt main, 1pc rear seal
brodix rr200 aluminum heads 2.055/1.60 valves
comp roller rocker 1.6
holley stealth ram intake
58mm throttle body
30 lb. hr injectors
eagle forged crank/rods/pistons
10.0:1 compression
slp shorty stainless headers
holley commander 950 fuel injection software
comp roller cam:.584I/.579E-duration @ .050=242I/248E
Old Jan 11, 2009 | 08:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: GLOWING HEADERS AT IDLE
How are you measuring AFR?
Old Jan 11, 2009 | 08:50 PM
creese187's Avatar
my commander 950 uses a laptop for tuning, and i see/adjust all the paremeters with the computer
Old Jan 11, 2009 | 09:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How is it measuring AFR then?
Old Jan 11, 2009 | 09:27 PM
creese187's Avatar
with a wide band o2 sensor located in the drivers side collector, this fuel managment system is made exclusively by holley
Old Jan 11, 2009 | 09:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try locking the timing out at about 34 degrees.
Old Jan 11, 2009 | 09:38 PM
creese187's Avatar
ive tried that too, i played with it from 25 all the way up to 45 before tdc at idle
Old Jan 12, 2009 | 09:09 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
Transmission: WC T-5 (untill it breaks)
Axle/Gears: 3.73 Posi
Make sure that your timing set is ok and put in the correct position.
Old Jan 12, 2009 | 09:14 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
new engines run very hot. i dont know if your heades are new but you should not run newly coated headers with a new engine.
they usually recommend breaking in the engine with old exhaust systems - to make sure not to overheat them.
once the engine is broken in, then put the ceramic headers on.
i dont know why but that is the way it is.
Old Jan 19, 2009 | 02:17 AM
SDCamaro1904's Avatar
Car: 1984 Camaro Z28
Engine: 305 H.O
ive heard clogged catalytic converters make your headers/exhaust manifolds turn glowing red.... dunno if this is your case...
Old Jan 19, 2009 | 08:07 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
I agree, happened on my Cherokee and made the carpet matting smolder and eventually the floor that was overheated turned into a nice big rusty hole. Even dried out the gravel where I pulled over to see what the heck was happening!
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Brendankup
Aug 30, 2015 01:46 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
