Won't start. Clicking.
Old Jan 16, 2009 | 06:46 PM
thunder-lips's Avatar
Car: 1989 Formula 350
Engine: building a 383 as of Feb. 09
Transmission: 700 R4, B&M shift kit
Axle/Gears: 3.23?
My firebird has been sitting outside for about 2 weeks. I tried to start it up to fix some stuff and it seems I have another problem to fix. When I try to start it up it makes a clicking noise, sounds like the starter. I see the alternator move a little bit. I just replaced the starter last year. I live in North Dakota, is it just too cold? The other problems I have to fix are the radiator hoses are leaking all up in the engine and the cross member is hanging on one side could any of this contribute to my starter problem? Please Help
Old Jan 16, 2009 | 06:47 PM
Beltfed's Avatar
Car: '86 Trans Am
Re: Won't start. Clicking.
Turn your lights on. When you crank if they dim alot, your battery is low. If they don't dim at all something is up with your starter. Check your voltage first.
Old Jan 16, 2009 | 07:00 PM
Axle/Gears: 3.23?
I had it hooked up to my other car and let the battery charge up a bit. Voltage looked normal.
Old Jan 16, 2009 | 07:03 PM
Beltfed's Avatar
Car: '86 Trans Am
If you saw the alternator turn alittle bit, the starter is engaging. Normally they don't do anything when they go bad. Was the other car running when the jumpers were connected?
Old Jan 16, 2009 | 07:43 PM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
That's right, if the alternator moves, the starter is engaging, at least somewhat. I would suspect a bad connection at either the battery or the starter. I would guess you are not getting enough voltage to the starter to turn the engine over. Clean up and check the battery connections, and when you jump the car, leave the other car running. Or better yet, charge up the battery out of the car and then try again.
Old Jan 16, 2009 | 09:27 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Just clicking is when when your battery isn't tight enough or the terminals are dirty. At least on my car that is what is does.
Old Jan 16, 2009 | 09:35 PM
Beltfed's Avatar
Car: '86 Trans Am
My Harley did that too. I had to take the cables off and use alittle sand paper to clean up the surface. It threw sparks too. I still think it's a battery/power issue instead of a bad starter.
Old Jan 16, 2009 | 09:42 PM
Axle/Gears: 3.23?
Hmm. I really don't think it is the battery or voltage. On the average it has been 25 below 0 at night. Could the oil just be too cold after sitting for two weeks?
Old Jan 16, 2009 | 09:47 PM
Beltfed's Avatar
Car: '86 Trans Am
What's the daytime temps at? I suppose it could be slightly frozen. Do you have a block heater for it?
Old Jan 16, 2009 | 09:59 PM
Mrgref92's Avatar
Car: 1986 Camaro Sport Coupe
Engine: L69
Transmission: 700-R4
Axle/Gears: 2.73's
My car did the same exact thing yesterday, I charged the battery and it fixed it, try charging it
Old Jan 16, 2009 | 10:13 PM
Axle/Gears: 3.23?
It's been about 10 during the day. Was looking for the block heater cord just now, but it is damn cold trying to find that outside with a flashlight. It's funny how many times I have been under that car and never bothered to check for that!
Old Jan 16, 2009 | 10:43 PM
Axle/Gears: 3.23?
I was wrong about the battery. I swapped it with one from one of my other cars. She's warming up right now. I am sorry I ever doubted the wisdom of third gen org. Thanks everyone!!
Old Jan 16, 2009 | 10:55 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Seems like you've got it fixed now, but I thought I'd comment on the temperature question. I used to drive my Camaro every day two winters ago. She'd start every day, even in minus 40 degree temps, after not having been plugged in at all. These things are fine in the cold. Glad you got 'er figured out though.
Old Jan 16, 2009 | 11:09 PM
Beltfed's Avatar
Car: '86 Trans Am
Woot woot!!
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
Jlanz55
Sep 29, 2015 08:55 AM
