Hesitation, Help Please!!!
Old Jan 18, 2009 | 10:16 PM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
I know this thread prob has been up before, but how can i get rid of my hesitation? I have a 91 WS6 T/A 305 TPI. Plenty of air flow with my cold air intake, i just put a new fuel and oil pump in and running with no cat. converter. When im just driving around it bogs and when i give it some more gas it takes a couple of seconds for the car to increase rpms and get rolling faster. This is obviously eating up a ton more gas, 10 mpg!!! and has been going on ever since i bought the car, any ideas? Thanks, Gary
Old Jan 18, 2009 | 10:34 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Hesitation, Help Please!!!
where is your tps set
are you aware of the throttle positioning sensor and how to adjust it
Old Jan 18, 2009 | 10:47 PM
Gary Berg's Avatar
Axle/Gears: Posi.
no never heard of it. where is it?
Old Jan 19, 2009 | 06:16 AM
jamon8's Avatar
Engine: 350 tpi
https://www.thirdgen.org/tpimod2
I just plug my voltmeter into the computer where it reads the tps
adjust to .54 volts with the key on
Old Jan 19, 2009 | 06:46 AM
Gary Berg's Avatar
Axle/Gears: Posi.
how much does a voltmeter cost?
how much does a voltmeter cost and where can i get one?
Old Jan 19, 2009 | 12:56 PM
Gary Berg's Avatar
Axle/Gears: Posi.
were is the sensor located?
Old Jan 19, 2009 | 02:11 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Check your timing and all of the components.
Old Jan 19, 2009 | 02:25 PM
Gary Berg's Avatar
Axle/Gears: Posi.
ill prob end up checking that too.
Old Jan 19, 2009 | 03:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
$10 or less, up to several hundred.
You'll need one that is high impedance. If it is digital, it will be high impedance. Most parts stores, Wal-Mart, etc., will have one for the lower price range.
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
