Strange ignition problem It Jumps
Old Jan 21, 2009 | 11:08 AM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I was trying to set the timing in my '87 camaro 4bbl the other day. I want it set to 5 deg advance. I took the appropriate plug off of the distributer and and used a timing light to set timing. The timing started at 0 deg or slightly retarded. when I turned the cap, the timing advanced smoothly until about 4.5 deg where it immediatly jumped to 15 degrees advanced. What the heck is going on?
I set the timing back to 5 deg advanced from there and it was fine. Then I shut off the car and restarted it and I'm at 5 deg retard. Any suggestions?
A friend of mine at work seems to think that it may have something to do with the mechanical advance in the distributor. Could this be? Where would I get an adjustable mechanical advance kit to replace parts? How would I test for problems?
Old Jan 21, 2009 | 06:06 PM
RazorN8's Avatar
Car: 1987 camaro
Re: Strange ignition problem It Jumps
bump
Old Jan 22, 2009 | 11:18 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I would try to lock the mechanical advance downand see it the timing stays steady. If the timing is boucing around during the timing process, then I would also look into testing the ignition coil. If you have an msd ignition, check on this site for msd ignition problems.
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Bryan F
Aug 18, 2015 02:28 PM
