Cam with Engine Help
Old Jan 21, 2009 | 05:17 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i bought a 350 tbi out of a truck only has 11k miles on it just wondering what is the max lift the stock heads can handle. The heads are the earlier style center bolt vc and i have 1.6 rocker are for them(not installed yet) just wondering whats the biggest cam i can go in this motor and i believe its a roller cam motor? im swapping this to a carb i have a holley 600 cfm getting an edelbrock performer rpm intake but i need to know the lift on the heads before i go and get a cam. any help would be greatly appreciated thanks.
Old Jan 21, 2009 | 06:17 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: Cam with Engine Help
anybody i need some help so i can order my cam tonight thanks.
perpetualjoshie's Avatar
Car: 86' Z28
Engine: 5.0l w/ new cam
Transmission: TH-350
Axle/Gears: 4.10's
i think the biggest you can go with stock cylinder heads like that would be about .470''. even that might be a bit to much. why waste your time on those garbage truck heads, i mean just about anything would be better then those, unless there the vortec style heads. do you know what year truck the engine came from?
Old Jan 21, 2009 | 06:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
+/- .460" but the only way to know for sure is to measure. There's no such thing as a Vortec TBI from the factory. It's TBI; they're swirlports.
Old Jan 21, 2009 | 06:53 PM
Car: 1991 Trans Am
Axle/Gears: Stock
ok cool guys thanks so much so no more than .470 lift then also is it a roller or flat tappet everyone tells me it could be both???
Old Jan 21, 2009 | 07:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If it's out of a truck, it's most likely flat tappet. They got roller blocks, but flat tappet cams.
Old Jan 21, 2009 | 07:23 PM
Car: 1991 Trans Am
Axle/Gears: Stock
is this motor a roller or flat tappet anyone know really need help with this please.
Old Jan 21, 2009 | 08:34 PM
ljnowell's Avatar
If it came from a truck its probably a flat tappet. There is only one way to find out, and begging on the net isnt it. You plan on chaning intakes, take it off and find out.
Old Jan 21, 2009 | 09:37 PM
Car: 1991 Trans Am
Axle/Gears: Stock
i did lol sorry for tbhe begging but i just got tired of asking when down and fiqured out myself and yes it is a hydraulic flat tappet.
Old Jan 21, 2009 | 09:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I said it was flat tappet before you asked the second time...
Old Jan 22, 2009 | 01:30 AM
ljnowell's Avatar
Old Jan 22, 2009 | 09:38 AM
Car: 1991 Trans Am
Axle/Gears: Stock
yeah but i didnt see that because we probably posted at the same time but w/e i went down there and took it apart myself with this guy from jegs helpin me out.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
