odd question with an 010 block in a 91 gta
Old Jan 21, 2009 | 08:10 PM
V6camaroman's Avatar
i picked up a 91 gta roller and i have a guy whos got a couple of 350 blocks for sale and 2 of them are 010 blocks. i know those were late 60's-70's blocks. my question is do they have provisions for the oil pressure switch and knock sensors?
Old Jan 21, 2009 | 08:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: odd question with an 010 block in a 91 gta
Yes.
Old Jan 21, 2009 | 08:19 PM
for sure they do? just checking because i looked at them the other night but it was too dark for me to see anything
Old Jan 21, 2009 | 08:23 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The knock sensor uses the block drain hole and they all have the 1/8" pipe thread by the distributor for the OP gauge.
Old Jan 21, 2009 | 08:32 PM
ljnowell's Avatar
The knock sensor was designed to fit the hole, not the other way around.
Old Jan 21, 2009 | 08:33 PM
ok is the knock sensor hole always on right right hand side of the block then? no matter what year?
Old Jan 21, 2009 | 09:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The holes are on both sides of the block.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
gta power
Aug 13, 2015 06:15 AM
BBSDesigns
Aug 11, 2015 07:39 PM
