corvette 350
Old Jan 21, 2009 | 10:15 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
corvette 350
would a 1990 corvette 350 tpi have a 4 bolt main block and/or a steel crank?
Old Jan 21, 2009 | 11:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: corvette 350
It should be 4 bolt main, not that it means anything. I don't remember if the crank is cast or forged in 1990. IIRC it was cast in the years leading up to that, though.
Both of those questions can be answered in a second with the pan off.
Old Jan 22, 2009 | 08:49 AM
blp226's Avatar
Re: corvette 350
I have had several C4s. I have a small library of books on them as well. I can tell you without a doubt that ALL corvettes are 4 bolt main blocks, and 85 and up were forged cranks. No doubt! My 85 was a 4 bolt with forged crank and so was my 89. And so is the 90. If there is not a forged crank in it then the original has been replaced or its not a vette engine.
Old Jan 22, 2009 | 08:59 AM
blp226's Avatar
Re: corvette 350
Make sure its got the aluminum heads. 87 and up vettes all had aluminum heads. There are lots of scammers trying to pass off 5.7 TPI Iroc engines for vette motors.
Old Jan 22, 2009 | 09:05 AM
blp226's Avatar
Re: corvette 350
Not exactly true. I had to rebuild the engine in my 85. It was a forged crank in it. 85 and up were forged cranks, and all 350 vettes got 4 bolt main blocks, C3s and C4s. Even the weak late 70s vettes were 4 bolt main blocks. I know this for a fact.
Old Jan 22, 2009 | 10:19 AM
89lt1's Avatar
Re: corvette 350
thanks to all who replied i was pretty sure it was for bolt i dont have it yet so i couldnt pull the pan.
Old Jan 22, 2009 | 04:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: corvette 350
Corvettes didn't use the 14088526 and 14088535 crankshafts?
Old Jan 23, 2009 | 06:50 AM
89lt1's Avatar
Re: corvette 350
so then it should be a 14088532 or 14088552
Old Jan 23, 2009 | 01:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: corvette 350
Which numbers is it though? I've only ever seen 14088526 and 14088535 listed for the F and Y bodies and those are both cast.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
