A TPI haunting
Old Jan 22, 2009 | 09:01 AM
joshua raymond's Avatar
Car: 87 GTA
Engine: TPI 350
A TPI haunting
If I crank the engine it starts as normal but shuts it self off after about one second. If I try holding the gas at about a third of throttle in an effort to keep the engine running, the rpms will rise to about 3000 and fall to 1200 a couple of times before eventually dying. The same thing will happen every time. There is no service engine soon light. I have, so far, tryed 3 different computers and 3 different chips. I have replaced the ignition module and verified it's wires' continuity, no change. I have checked voltage at the ECM pinouts and all voltages in tolerance. Does anyone have suggestions on the direction I might want to take the troubleshooting? Or maybe you can relate to this and share your experience, maybe we can determine a common factor involved.
Old Jan 22, 2009 | 10:34 AM
toybuilder's Avatar
Re: A TPI haunting
It sounds like a fuel issue to me check the injector resistance and check fuel pressure
Old Jan 22, 2009 | 01:33 PM
tim_lemmy's Avatar
Re: A TPI haunting
it sounds like either your tps needs to be replaced or your cat is clogged. The fact that it starts make me think it's not electrical. It could be as simple as the O2 sensor going bad and the car is running too rich. Sometimes cars will store codes even without a light being lit... I recommend that you run the codes and see what you get.
Old Jan 22, 2009 | 04:26 PM
jfsiutza's Avatar
Car: 1986 Z-28 al unser silver bullet
Engine: 305 carbed
Axle/Gears: 3.08
Re: A TPI haunting
i had the same problem... cat or muffler is may be probably clogged.. i replaced TPS intake gaskets.. injectors fuel pump MAF MAP ECM Wiring harness.. it was crazy.. never worked till i removed the exhaust pipe from the headers.. and it ran fine...
thats jus my input on this..
Old Jan 23, 2009 | 10:36 AM
Car: 87 GTA
Engine: TPI 350
Re: A TPI haunting
Right now it has open headers and the TPS did seem to check out good.
Old Jan 23, 2009 | 01:36 PM
jfsiutza's Avatar
Engine: 305 carbed
Axle/Gears: 3.08
Re: A TPI haunting
well ill go wit tim_jimmy's input.... sounds electrical..
Old Jan 23, 2009 | 02:52 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: A TPI haunting
Check the fuel pressure.
Old Jan 23, 2009 | 02:55 PM
tim_lemmy's Avatar
Re: A TPI haunting
I said it doesn't sound electrical. the fact that it starts at all makes me think that...
I'm pretty sure it's fuel related...
Does your car have the special key that causes the fuel pump to work? (supposed to help reduce theft) or can you go to walmart and get one? If that's the case you could need a new key or if the key is good you may need a fuel pump
Also before you go and spend any money make sure all your vacuum hoses are connected properly. My brother's 91 Formula had a similar problem... I looked under the hood noticed a loose hose reconnected it and it cranked and ran just fine.
Old Jan 26, 2009 | 05:51 PM
Car: 87 GTA
Engine: TPI 350
Re: A TPI haunting
fuel pump is brand new, it is a bosch from TPIS. but i will take another look at it?
O2 is also brand new, a heated one also from TPIS.
Last edited by joshua raymond; Jan 26, 2009 at 05:52 PM. Reason: Automerged Doublepost
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
