Removing Valve Covers?
Old Jan 22, 2009 | 05:17 PM
Crux's Avatar
Car: 1987 Camaro
Engine: V6 2.8L
Axle/Gears: stock?
I know it's an amateur question, but I'm having trouble getting them off.
I've gotten the nuts and bolt off...but it doesn't want to budge.
I, experimentally, tried prying it a little.but I don't think I could do it withou damaging something.
Could I be missing something? When I take the oil cap off, I can see a bolt in there..do I have to take it out first?
Thanks for any replies.
As I go along, I'll be able to return the help.
Thanks and later.
Old Jan 22, 2009 | 05:53 PM
Crux's Avatar
Car: 1987 Camaro
Engine: V6 2.8L
Axle/Gears: stock?
Re: Removing Valve Covers?
Nevermind. I found something better to pry it off with and come out without a problem.
Thanks anyway.
Old Jan 22, 2009 | 09:48 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
A couple smacks with a rubber mallet work well too.
Old Jan 22, 2009 | 10:03 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Rubber mallet if you have one, if not a regular hammer with a piece of 2x4 between hammer and cover.
Old Jan 23, 2009 | 07:25 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I might want to check the trueness of the mating surface of the valve covers
did you notice any rtv on the gaskets
this is what makes the covers hard to get off most of the time
and most of the time if you have to use rtv the covers are a bit off
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
