Car wont start only with emergency starter!!
Old Jan 22, 2009 | 08:47 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
my iroc will not start.....it only starts with the emergency starter what can it be everything works fine i just cant start it with my key any clue??
Old Jan 22, 2009 | 09:49 PM
Beltfed's Avatar
Car: '86 Trans Am
Re: Car wont start only with emergency starter!!
What's an emergency starter?
Old Jan 22, 2009 | 10:12 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
I'm guessing it's the button attached to a long cord that you hook up to the starter directly. Is there a fuse or a fusible link between the switch in the column and the start that could be fried?
Old Jan 23, 2009 | 12:15 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
screwdriver you jump the terminals on the starter with
id check between the starter and ignition cylinder. use a test light and start prodding the wire from the ignition cylinder until you find connectivity then work backwards..
ie. say you start at the column and find nothing, but you go further down and find power after the ignition switch, BINGO, bad switch get it? you need to find where the power is being cut off, im guessing its there because if you can run the starter its obviously hooked up right, but you cant run it with the key, trace it from one end to the next and find the culprit in between
Old Jan 23, 2009 | 12:32 PM
Engine: 350 tpi
hmm i found out the previous owner had a kill switch and it dis connected so thats why it would not start
Old Jan 23, 2009 | 01:20 PM
Engine: 350 tpi
Well that did not work the car threw code 43???
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
