Which heads??
Old Jan 23, 2009 | 09:17 AM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
Which heads??
Hey all, I know I don't post here often, but when I need real advice, I come here (local car club is a bunch of ls1 dorks) Ok, I am going to get a new set of heads for the race car with part of my tax return. I am running protopline vortecs now, they are the small intake runner, 1.96 1.50 valves, and iron So my requirements for the new heads: aluminum, >190 intake runner, 2.02 1.60 or bigger valves, a 64cc or smaller chamber, and would like to see flow numbers greater than 265@.500 lift, angle plug would be best (runnin long tubes ) I was looking at the dart pro 1's, afrs are a little on the pricy side, and powerhouse heads. The powerhouse heads I can't find anyone with any experiance using them, are they a good quality? Do they flow as well as they say they do? Oh and lastly, I would like to keep them under the $1200 mark. Just looking for options, thanks guys!
Old Jan 23, 2009 | 10:44 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Which heads??
Go to Racing Heads Services on the net, they have a wide selection of heads, I have a set w/2.08 valves that flow those kind of #'s and love-em. They have a wide selection to pick from. Comp Cams has recently acquired them, they offer complete packages w/ or w/o valvetrain.
Old Jan 23, 2009 | 12:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Which heads??
The Trick Flows is what I always recommend when AFR's are too much, but I dont know if they're >$1200. I think they are though.
Darts are good, too.
I've never heard of Powerhouse heads.
Old Jan 23, 2009 | 02:56 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
Re: Which heads??
https://shop.enginekits.com/osb/itemdetails.cfm?ID=2910
These are the powerhouse heads.
I'll check out what kind of options rhs has.
Trick flow has like 50 diffrent options So I suppose I'll have to sort through them and see what would work for me.
Has anyone done any comparisons between the tfs and the darts?
Old Jan 23, 2009 | 11:00 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Which heads??
I would stick to one of the major head companies. Powerhouse as you listed is not one of them. Those are probably the same ones as the poorly casted Pro Comps.
Stick to Dart, World, Brodix, TFS, RHS (formerly Pro Topline, bought by Comp Cams). The known companies. I've dealt with them all, and they're all good stuff. I would take an entry level iron head from any of those companies before I would go to those 190cc's that you list.
Old Jan 24, 2009 | 12:10 AM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: Which heads??
Have you look at summit racing? they have a set of 2.02/1.60 heads with a 64cc chamber, 200cc intake runner @$949. part # is SUM-162111 for more info. probably just a step below trick flows, but look like a good budget option.
Old Jan 24, 2009 | 03:50 AM
J91's Avatar
J91
Re: Which heads??
I would have to agree, stick w/ a known reputable co. AFR, Trickflow, RHS, Dart.... Ihave found out the hardway in the past. You get what you pay for! It's better to wait a little longer and spend the extra$, for a quality product.
Old Jan 24, 2009 | 10:08 AM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
Re: Which heads??
Thats what I came here for I'll stick with a name brand. I was looking for about 3 hours last night, and I REALLY like the afr 195 eliminators, they have awsome flow numbers. But they are close to $1500. I couldn't find any flow numbers on the trick flows (besides there 18* heads) does anybody know where to find flow numbers for the rest of their heads? Thanks again guys.
Old Jan 24, 2009 | 11:24 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Which heads??
Canfield makes an awesome head for the price. Mine cost under $1100 shipped to my door from Competitionproducts.com.
With the 195's right out of the box I'd say my car is making over 450HP at the wheels naturally aspirated based on its weight/mph - Keep in mind it's a pump gas street cruiser, nothing fancy.
Old Jan 24, 2009 | 01:19 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: Which heads??
Summits heads from what I hear are Canfields.They just don't have thier name on them.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
