New engine, car runs weird. HELP PLEASE!!
Old Jan 25, 2009 | 10:04 PM
camaro_70's Avatar
Just rebuilt the engine in my 1990 camaro, all stock other than pro comp heads, lt4 hot cam, and slp runners. Had pcmforless burn a chip and car ran great. Engine lost oil pressure shortly after install, so i tore it apart and fixed that problem. Now for the fun part. After installing engine again the car shows ses code number 43 and when i put it in gear it shakes and runs horrible, and when i try to give it some gas it will not accept it and wants to die. Eventually when i play with it just right i can get it to go down the road and it runs mediocre. I have tried unplugging knock sensor and pretty sure everything is plugged in correctly. I am at my wits end trying to fix it so any help would be greatly appreciated.
Old Jan 25, 2009 | 10:25 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: New engine, car runs weird. HELP PLEASE!!
you check the ignition timing?
Old Jan 29, 2009 | 09:09 PM
camaro_70's Avatar
thanks for the response. yea i have the initial timing set at 8 degrees. Any one else have any more ideas? I am in a bind. I have tried resetting the computer and code still comes back and problem presists. Is there a way to by-pass the knock sensor? Please help....
Old Jan 29, 2009 | 09:32 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
code 43 = electronic spark control, check the voltage at the ecm a-b connector terminal b7;it should be over 6 volts unless the system is sensing detonation.check for loose connection. replace the esc sensor and/ or module,jimmy
Old Jan 31, 2009 | 03:03 PM
camaro_70's Avatar
what is the module you are speaking about?
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
Kaweh
Aug 9, 2015 02:54 PM
