Starts but imediately dies
Old Jan 31, 2009 | 09:37 AM
tachman's Avatar
I am helping my son with his 87 Iroc. He drove it the other day, all was normal then wouldn't stay started. We changed the fuel filter, checked the lines, pressure is ok, as far as I can tell the fuel pressure regulator is good. The diaphram isn't leaking anway. No codes show up either. The trouble chart says something about removing or disconnecting the distributor by-pass lead ?? What's/where this?
Disconnected ECM no help, No moister under cap ( my first thought ), injector fuses good
TPI, 305, Standard coil not HEI
Thanks for the help, I am trying to get it running so I can have my car back.
Old Jan 31, 2009 | 09:50 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Starts but imediately dies
sounds like vats but I am not sure a 87 had vats or not
how are you checking the fuel preasure?
so you have a noid light to check the injectors
you could take out your ignition module and take it somewhere to get tested
oh by the way if you have vats you will have a chip in your key.
good idea at the time but now that the system is old it tends to have issues
Old Jan 31, 2009 | 09:54 AM
tachman's Avatar
No VATS
We didn't have a gauge will get one today but got a lot of flo out open line and couldn't hold back the pressure with my thumb. I know it's not accurate test but still lots of pressure. It fires like once or twice and that's it don't truely "start"
He checked the fuses under the dask, I assume these are all the fuese? Or is there another location for the injector fuses. They show 2 in the book. But not where they are at. Only found 1 in the fuse panel
Old Jan 31, 2009 | 10:19 AM
tachman's Avatar
Thanks for the inputs I recieve here. I am knew to this forum. I have been reading other threads to see if I can pick up anything. I noticed someone asking to close the threads when we are done. Sorry I don't know how and not all that great on computors anyway. Took me awhile to get this far. So when I am done I will close with a very grateful thanks but please tell me how.
Old Jan 31, 2009 | 10:35 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Check for spark when it won't start. Easy enough to do and won't require any special tools. Just pull a lead off one of the plugs and hold it (with insulated pliers) a short distance away from a ground. Have someone hit the starter and you should see the spark jump the gap. You may need to put a screwdriver or other conductor into the boot to do this.
If the spark is good, go on to check air and fuel.
To close out a thread, just post back when and how it was resolved. Let's us know it turned out alright and may help someone later when searching with a similar problem.
Old Jan 31, 2009 | 10:41 AM
tachman's Avatar
Thanks, I am assuming and I know that ain't good but before I showed up on the scene they shot starter fluid in the intake and it ran on that so I assume good spark.
Old Jan 31, 2009 | 10:56 AM
naf's Avatar
naf
Wouldn't hurt to duplicate that test again, especially immediately after a no-start condition. That would rule out air and spark and you could concentrate on fuel. Go on to test pressure and injectors.
A common failure is the ignition module. It will start when cold, run fine all day then refuse to re-start while it's hot. A few hours to cool down and it will work fine. Why it's important to check spark while it's refusing to start before moving on.
Old Jan 31, 2009 | 10:59 AM
tachman's Avatar
Ok will do more testing.
This is a TPI intake FYI
Old Jan 31, 2009 | 11:01 AM
naf's Avatar
naf
Yeah, 8 (or 9) injectors. Fuel pressure requirements are much higher than TBI and more likely to cause problems.
Old Jan 31, 2009 | 11:07 AM
tachman's Avatar
9 injectors
Old Jan 31, 2009 | 11:09 AM
tachman's Avatar
What PSI should I get?
Old Jan 31, 2009 | 11:11 AM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
42 psi or higher,jimmy
Old Jan 31, 2009 | 12:07 PM
naf's Avatar
naf
Been replying too fast and some of my earlier posts were double merged. Make sure you didn't miss anything.
Again, most likely IMO is fuel but spark is too simple to rule out.
Old Jan 31, 2009 | 04:45 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
It does sound like your pump is not able to keep the pressure it needs. Either the pump strainer is clogged or the pick up line is cracked.
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
EFR2000
Aug 18, 2015 08:54 PM
