305 HO difference?
Old Jan 29, 2009 | 02:00 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
305 HO difference?
I have an IROC 305 5 spd. I understand that these were the H.O. engines. What's the difference with this engine vs the standard 305. I understand it puts out a little more power, but why?
Old Jan 29, 2009 | 02:09 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: 305 HO difference?
I take it you have the L69 H.O. They had a more aggressive cam, 750 q-jet, dual snorkel intake, and I believe they had a better flowing exhaust. Plus 5 the spd and I think they were the only 3rd gens to come through with 3.73's from the factory.
Old Jan 29, 2009 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The IROC didn't automatically come with the L69 (vin G). Mine was originally an LG4 (vin H).
https://www.thirdgen.org/forums/faq-...5-engines.html
JamesC
Old Jan 29, 2009 | 03:22 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The 8th digit in the VIN would be the letter G to be an L69 5.0L HO car. The L69 had a better camshaft with more duration and lift, flat top pistons for 9.5:1 compression with electronic detonation control, exhaust manifolds with larger outlets, larger diameter exhaust system with higher flow catalytic converter, retuned carburator and computer programing for more ignition advance, electric cooling fan, and 3.73(10-bolt) or 3.70(9-bolt) rear axle ratio.
Some of the L69 improvements were eventually incorporated into the base LG4 5.0L engine and by 1987 it was producing an additional 25HP over it's original 1982 145HP rating.
Old Jan 29, 2009 | 06:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/1987-chevy-camaro
You'll find no L69 there.
You may have an LB9, with TPI. However, it was not designated "HO".
Old Jan 29, 2009 | 09:07 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Yep, I looked it up again. Guess it is the LG4.
Old Jan 29, 2009 | 10:50 PM
five7kid's Avatar
Are we talking about the '85?
Old Jan 30, 2009 | 11:43 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
yep.
Old Jan 30, 2009 | 03:54 PM
five7kid's Avatar
Little tidbits like that are nice to know when questions like this are asked.
Old Jan 30, 2009 | 03:58 PM
Joiner's Avatar
Car: 1991 Firebird Base
Engine: 3.1
Transmission: 700R4 Automatic
Vin letter H is the L69, which my car has.
Old Jan 30, 2009 | 03:59 PM
Joiner's Avatar
Engine: 3.1
And I don't believe I have the 3.73 but how could I find out? I only have one wheel peel right now and rear drums. I believe it's a GM 10 bolt.
five7kid's Avatar
VIN letter H is the LG4, the lo-po version.
The L69 is VIN letter G.
Old Jan 30, 2009 | 04:03 PM
Joiner's Avatar
Engine: 3.1
I have a 305 with an electronic controlled Q-jet carburetor but I only have one snorkel because it's a firebird, and I'm sure it's Vin is H.
Old Jan 30, 2009 | 04:06 PM
Joiner's Avatar
Engine: 3.1
Just went outside, Vin H. And I didn't think LG4's came in Trans Ams unless they had the manual, which mine does not.
Old Jan 30, 2009 | 04:20 PM
Joiner's Avatar
Engine: 3.1
Damn, did some more research and my car has the LG4, how depressing.
Old Jan 30, 2009 | 04:36 PM
Dens71TA's Avatar
The standard engine in the Trans Am was the LG4 from '82-87. Manual trans was standard with automatic optional.
LG4 is VIN H for all years. L69 is VIN 7 in '83, and VIN G for '84-86. The L69 was only available in the Z28 and Trans Am. No lesser model Camaros or Firebirds.
Trans Am LG4 and L69 used the same single snorkle air cleaner with functional ram air for '83-84. Since the refreshed T/A went to a flat hood in '85 the L69 cars got the same dual snorkel air cleaner that the Z28 L69 cars had from the beginning.
Old Jan 30, 2009 | 06:15 PM
armac's Avatar
Car: 83 ta
I have a set of HO heads in the garage and the exhaust valve is larger than the intake. That is the main diff between the two engines. They did also come with a more aggressive cam as posted above.
Old Jan 30, 2009 | 11:10 PM
five7kid's Avatar
I don't know what you're looking at. LG4 and L69 heads were identical in every detail. And, intake valves are always larger than exhaust valves.
Old Jan 31, 2009 | 07:39 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I'd like to see a picture of those heads, they must be one of a kind and very valuable!!!
Jake_92RS
Jan 28, 2020 10:37 PM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
