Changing spark plugs
Old Jan 29, 2009 | 10:02 AM
87IROCZ53's Avatar
Car: 1987 IROC-Z Z-28 Camaro
Engine: 305 TPI V8
hey are there any tips or tricks that yall can pass on to help me change the plugs, wires and cap for my IROC Z?
Old Jan 29, 2009 | 03:43 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Changing spark plugs
Don't use plugs with the screw-on tips.
Old Jan 29, 2009 | 06:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Headers, or stock exhaust manifolds?
Nothing wrong with them. Loosen the tip a little, squeeze it down a little in the vice, tighten it back down. It'll stay put.
Old Jan 29, 2009 | 07:49 PM
90 L98 TransAm's Avatar
Car: 90 L98 TA, 03 WRX
Engine: Vortech Supercharged 5.7 L
put anti-sieze on the plug threads and a little dielectric compound inside the plug wire boots to make them easier to remove in the future.
i had to disconnect the A.I.R. tubes on the driver's side to get at the second plug up from the firewall.
Old Jan 30, 2009 | 11:18 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Some of the plugs are much easier to get from under the car. Like #5 and #7 mentioned above.
Old Jan 30, 2009 | 11:41 AM
kcb37's Avatar
When I did mine, I used a rachet, spark plug socket 2 or 3 extensions, a u-joint, 3/4 wrench and a stubby wrench.
You can put the wrench on the outside of the socket if you cannot get a rachet to it.
My car is an 89 RS with shorty headers. Don't know what brand they were on when I bought it.
But I got all of mine from the top. Took a little bit but not to bad.
I did have to get header plugs though.
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
