92' firebird hand brake
Old Feb 1, 2009 | 01:50 PM
Raz's Avatar
Raz
Do I have to get under the car or can I access the adjust screw from the center console?
Old Feb 2, 2009 | 12:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Underneath. Above the driveshaft.
Old Feb 2, 2009 | 11:55 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 92' firebird hand brake
What he said. Plus;
1/4" wrench to hold the stud still, 13mm wrench (or was it 10mm?) to tighten the nut. Bring PB blaster or WD40 or whatever you have, it will most likely be seized.
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
colton_carlson
Mar 8, 2019 12:21 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
