Need help to ID# (TBI orTPI) correctly.
Old Feb 4, 2009 | 04:38 PM
pony exp.305's Avatar
Hey,
I need to know, look at those camshaft/lifters> what it is for TBI or TPI what I found from barn in Appalachian Mountain where I live in Tennessee.
Pix here:
What about the block? wait for VIN# come up and click on that pix.
http://www.slide.com/r/JdcgzAiH4T-uG...&view=original
Old Feb 4, 2009 | 05:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's not the VIN, that's the casting #. 14093638 is a common 350 one-piece rear main seal roller lifter block, could be from a truck, f-body, Vette, Caprice, etc.
083 heads and 2-bolt mains were used for the f-body TPI engines. If it was all from the same engine, it's probably a TPI.
Old Feb 5, 2009 | 07:23 PM
Re: Need help to ID# (TBI orTPI) correctly.
Wonder, can that Camshaft (look at post#1) and valve cylinder heads from TPI could be interchange in 305 TBI, would it work? better/strong run?
Old Feb 11, 2009 | 11:25 AM
I assume that question is stupid..I did search and won't work to be interchange 305TBI -350 tpi.
I would go selling those tpi things...
Old Feb 11, 2009 | 02:09 PM
five7kid's Avatar
Depends upon your definition of "work".
Would it run? Sure. Would it be a good combination? Probably not.
Why not use the whole 350 engine?
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
NZKnight
Oct 15, 2015 02:47 PM
tmellott89
Oct 14, 2015 02:06 PM
shanelique22
Oct 3, 2015 07:23 PM
