vavle size on a 90 5.0tpi?
Old Feb 5, 2009 | 08:00 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
are they 1.60 1.94?
Old Feb 5, 2009 | 08:11 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: vavle size on a 90 5.0tpi?
I think they are 1.84" Intake and 1.50" Exhaust... Casting number on those heads should be 14101081. I think the chamber size is 58cc.
Just run a quick search for that casting # (14101081) and you should get some info. Here's the thread I turned up on a Google search that gave me the valve sizes (reply #4). Hope that helps.
Old Feb 5, 2009 | 08:13 PM
Damon's Avatar
Agreed. 1.84/1.50 on a stock head.
Old Feb 5, 2009 | 08:17 PM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
anyone know what the stock cam specs are on this motor and what the largest can that can be run with the stock springs?
Old Feb 5, 2009 | 08:53 PM
BlueIroc-Z's Avatar
Here are the stock cam specs for 1990 (scroll down the page a little). Unfortunately I can't answer your question about the max lift on stock springs, but I'm sure someone else will come along with an answer for that. Good luck.
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
