350 vs 383
Car: 87 iroc-z28
Transmission: th350
350 vs 383
I have a 350 4 bolt in my garage just waiting to be built, and I am debating between building it as a 350 or a 383. I was wondering what some of the advantages/disadvantages of each were.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: 350 vs 383
If you're looking at buying a complete rotating assembly, just go with a 383. 383 and 350 rotating assemblies pretty much cost the same. You'll make more power with a 383.
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: 350 vs 383
do you have anything else? like crank,rods,pistons?
hopefully you at least have the main caps.
is it a roller block?
what do you want to use it for?
Car: 87 iroc-z28
Transmission: th350
Re: 350 vs 383
Right now its just a bare block that I will be taking to the machinist soon. I would like to see at least 400 horse out of it and throw a 100 shot of nitrous on it. This is my big project motor since i already have a mild 350 in the camaro, so I'm not looking for a cheap build.
Re: 350 vs 383
Then make it a 383 with forged crank,rods,pistons...JE,Eagle,ect..
Small roller cam nos compatable, like 224-236 int. and 5-10 more on exhaust.
that will make nearly 480 hp and tq. w/o nos, and you could hit it with 200 shot of nos. for years. Good heads,good intake...do it once.
If that is too much you can use cast crank,recond. rods,hyper claimer pistons, same cam and everything else......use keep the nos 50-100hp and the rpm below 6500 better yet 6000 rpm. that will last longer that most think. I know I have one just like it...but no nos, bigger cam, and hitting 7000rpm with a comp 292 cam...yeahhhh baby. when I took the 5.7 gm rods to be resized the machinist sasid they where 2-300 thou out..lol
Re: 350 vs 383
Advanage-almost the same price, lower cruise rpm, more tq., power at lower rpm range.
Disadvantage-a little more $ for machine work or doing yourself, clearancing the block,steam holes in the heads,balancing maybe. more $ to make internally ballanced, .....lost of tire tracting..lol
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: 350 vs 383
you should go with a 350 and sell me the 383 for cheap
kidding. def go with the 383 though.
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 350 vs 383
they dont only need steam holes for 400cid block engine builds........as in like a 377....just get a good scat 383 rotating assembly for around 1k and take it and the block to the machine shop and have them build u a short block...the price difference is negligible
Re: 350 vs 383
I messed up...thinking of a 400 sbc. No stgeam holes needed in the 383 only 400 for street use....I just wanted to see if anyone else was pay'in attention...my bad
Car: 87 iroc-z28
Transmission: th350
Re: 350 vs 383
Thanks for all the input, sounds like 383 is the general consensus. I was planning on doing a forged rotating assembly, not sure which one yet though. We have a great machinist in town who is gonna help me figure out what the best parts are going to be.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
