oil leak on new 383
Old Feb 12, 2009 | 04:56 PM
flint502's Avatar
oil leak on new 383
i built a fresh 383 recently and noticed when i turn the engine off, there is oil inside my crank pulley. it looks to be coming fron the damper bolt and being thrown all over the inside of the pulley. any info on why this is and how to fix it would be a great help.
Old Feb 12, 2009 | 05:12 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: oil leak on new 383
Depending on how the balancer was fit to the crank. You might need to put a small amount of RTV on the snout of the crank. It also could be the front seal. If the motor sat fr a while before being started the seal might have dried up.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
