TPI FUEL PRESSURE
Old Feb 15, 2009 | 01:56 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
TPI FUEL PRESSURE
i jst got my new 350tpi camaro a few weeks ago and decided to check the fuel pressure the cars seems like its running pretty good but it says i have 34psi and when i squeezed the return line with dikes it jumped all the way up past 90psi so this means the fpr took a **** right also if i do buy an after market fpr what should i set it to and what kind of gains could i expect
Old Feb 15, 2009 | 02:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI FUEL PRESSURE
34 psi is normal. Try removing the vacuum line to it and then see what the pressure goes up to. It should go up to about 42 or 44 psi. When you squeezed the line and the pressure shot up, that is normal too.
Any of the aftermarket fuel pressure regulators are pretty good. You have to adjust the pressure yourself and see what the car likes. 44 to 46 psi is a good place to start.
Old Feb 15, 2009 | 05:50 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
yea 34-40 is about normal. Just finished diagnosising a crank no start on my Z28 today mine was 38 psi...
Old Feb 16, 2009 | 01:33 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i just ordered a fpr from sk speed today. when i get it at say i start at like 42psi how will i know whats best. is it all by whatever feals best performance wise. also how will i know if its too much bec my cars bone stock right now
Old Feb 16, 2009 | 04:35 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
You will probably not see any performance gains at all on a stock motor. I would keep it right around 42 psi with the vacuum line unplugged.
Old Feb 16, 2009 | 12:26 PM
Kevin91Z's Avatar
If the car is all bone stock, then a fuel pressure regulator wont give you much benefit. But yes you start at 42 psi and run the car on a dyno or at the track, and then keep raising the pressure until the car stops making more power.
Same with your timing. Set it at the stock 6* and raise it to 8* or 10* until it stops making more power, then back off.
92camaroJoe
Jul 29, 2023 07:57 PM
Brcharrelson
Aug 26, 2015 07:47 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
