timing help
Old Feb 15, 2009 | 07:01 PM
1991TransAm's Avatar
Car: 1991 Trans Am GTA
Engine: 357sbc
Transmission: TH350
Axle/Gears: 2.73 stock rear
timing help
what do you set the timing at on a tpi car and what do you guys set it at to get the most out of the car with out hurting anything? the motor is a 357 with a cam,hi flow base,slp runners,24lbs injector,ported heads and intake to match,shorty headers.
Old Feb 15, 2009 | 09:20 PM
ChoobinatoR's Avatar
Re: timing help
i set mine to 6 degrees advance, from what it looks like is pretty standard. i run basically stock tpi. i can't answer the other question, seems timing varies quite a bit based on whats under the hood.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
