Need a new Starter
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Need a new Starter
I have a 92 Camaro originally 305 tbi but now a carb'd 358. My starter is getting old and weak and I need a more powerful one. I'm not sure if i should buy the oem one or not, it doesnt start the car that great once its been running for a while, because of my higher compression. also, ive heard there is a security wire that runs to the starter? So i'm not sure whether or not I have to buy one of that nature, or if i can go with any high torque starter. I'm not familiar with starters and i've never installed one, but i have my exhaust and heads off now so it would be a great time to replace it. If you guys have any suggestions on which one i should buy that would be great. Thank alot. MC
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: Need a new Starter
Transmission: 4L80E/4L80E
That's the starter I'm using on the 396 in the '57.
The security system is VATS. It doesn't affect what starter you use.
Gunner242
Dec 25, 2015 04:49 PM
