Car Smoking Bad
Old Feb 19, 2009 | 08:26 AM
federal's Avatar
Car: 1991 firebird/1982 trans am(sold)
Engine: 305/ 383 soon
Transmission: th700r4
Axle/Gears: 10 bolt 2.73
Car Smoking Bad
Well my car has been smoking really bad and is not driveable anymore... It has no power at all and shifts terrible.. I was thinking that it was bad rings but didn't know for sure.. My question is can it just be valve seals and if so how would I go about knowing.. I know how to check them just don't know what they should look like.. If you can post a picture that would be so helpful...
Old Feb 19, 2009 | 11:34 AM
toomany's Avatar
Re: Car Smoking Bad
Does it smoke when under a heavy load (accelerating hard)? Then it's most likely the rings. If it only does it when you start it, then it could be the valve seals. But you saying that it has no power leads me to believe it's the rings. The cylinders can't build presure because it's all leaking past the rings. How many miles are on the motor?
Old Feb 19, 2009 | 11:59 AM
federal's Avatar
Re: Car Smoking Bad
150,000 + miles on it right now... The car smokes when I start it and just keeps smoking and smoking... It is dumping oil out of the tailpipe too...
Old Feb 19, 2009 | 12:04 PM
toomany's Avatar
Re: Car Smoking Bad
If it keeps smoking (and dumping oil out the pipe) then I'd believe it's the rings. Or possibly the PCV valve (even the worst ones shouldn't smoke a whole lot though). Either way it sounds like you're going to be in for a rebuild soon.
Old Feb 19, 2009 | 01:15 PM
federal's Avatar
Re: Car Smoking Bad
Yes I most certainly am... That's why I'm going to build me a nice 383 to take the place of this sick 305 (cough cough).
Old Feb 19, 2009 | 02:06 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Car Smoking Bad
Have you checked to see if it's just a failed intake gasket yet?
Pull ALL the plugs and what do they look like?
Old Feb 19, 2009 | 02:27 PM
federal's Avatar
Re: Car Smoking Bad
not haven't done that yet but didn't know it could be that and if it could blow oil out the tailpipe... I know it would smoke but didn't know it could cause it to leak oil like I said out tailpipe.. I will check and see though...
Old Feb 19, 2009 | 04:13 PM
federal's Avatar
Re: Car Smoking Bad
I got a friend of mine coming over to run a compression test on my car and see if we can fix it....
bryan623
Mar 22, 2021 06:43 PM
86IROC112
Apr 9, 2016 10:20 PM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
