sudden death woes
Old Feb 17, 2009 | 07:11 PM
gmapostle's Avatar
Car: 89 rs t top
Engine: 5.0 with all the bolt ons and nos
Transmission: stage 1 700r4 2200 stall
Axle/Gears: 3.73 auburn posi
sudden death woes
alright third gen gurus, i've got an 89 rs 5.0 tbi 700r4 that i've had a couple of intermittent problems with. on occasion i'll slow down for a stoplight, stop and the car will idle for a couple seconds and die. it will promptly start back up again and sputter to death again. after one or two times of doing this, it starts up fine and runs no trouble. fuel pump? also on occasion, the car will not start. i have all gauges, radio, all that, but turn the key and nothing, but when i let off the key everything works again. won't start if i hit the starter, play with the battery cables, nothing. yet i can walk away for 20 minutes and it will start up. am i losing my harness or do i have a fusible link going out or wat? finally, if i'm in fourth gear on the highway, my car will surge unexpectedly like it's totally lost power, but when i give it full throttle or kick it into third it goes away. the tranny was rebuilt a year ago, is my lockup going out or is it again the fuel pump? any help would be greatly appreciated
Old Feb 18, 2009 | 07:15 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: sudden death woes
theres a stud on the back of each head,has ground wires hooked to them. take a wrench and retighten them. see what happens,jimmy
Old Feb 18, 2009 | 07:41 PM
50bmgshooter's Avatar
sounds like for your first prob a fuel filter.
as for the second it sounds like the vats system. these cars are known for this prob.
Old Feb 19, 2009 | 05:12 PM
gmapostle's Avatar
Car: 89 rs t top
thanks i'll check the heads. now how do i go about checking the vats system?
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Jlanz55
Sep 9, 2015 09:09 AM
greenyone
Sep 8, 2015 08:41 PM
