Ignitions switch removal/replacment help
Old Feb 19, 2009 | 09:06 PM
Midniteson2's Avatar
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
Hey guys, my 91 Lo3 bird has had starting issues for a while. ive replaced the battery, and starter recently and it still wont start all the time. my next step is to swap out the ignition switch. what the car has been doing is sometimes i'll turn the key and it'll fire right up. somtimes i get nothing not even a click. but if i continue to turn the key off and than to start over an over it will fire up. and somtimes the car will turn the engine over really slowly like its in slo motion but it usually fires up. Anyone with tips or advice on removing/replacing the ignitions switch would be really appreciated. has anyone else run into a similar problem what was your solution? thx in advance.
Old Feb 19, 2009 | 09:28 PM
RobSS1113's Avatar
Re: Ignitions switch removal/replacment help
You know what I have that same problem, so can you PM if you do replace the ignition and PM to let me know if it worked?
I replaced my friends ignition on his 91 Camaro cause the fool lost the keys, and I by passed his vats also, I had to try different resistors to find out which one would work .. turned out my 2 try worked !!
anyways I told Him I would replace his switch if he let me use his car as a ginny pig for my first time swappign ignitions on a car with an Airbag. He agreed. if you have a steering wheel puller GREAT !!! if not go rent one at Oreilys or someother parts store. Disconnect the battery .. undo the torx screws from behind the wheel these hold the airbag. put the pulled on the Nut and extract the whell out. Make sure if you can to have your wheel straight and your tires straight so that way you can center it when you put it back.
once you get the wheel off your gonna have to put pressure inwards to push the plate back so you can take a ring off the shaft ... once these are taken off replacing the switch is a piece of cake. good luck !!
Old Feb 19, 2009 | 10:52 PM
toomany's Avatar
If you rent a wheel puller, also get a lock plate depressor. It threads onto the steering shaft and has two arms that will press the plate down. You can get the plate off without one...but I doubt you'll get it back together without it.
Also a harmonic balancer puller will work to pull the wheel, just need the correct bolts.
Old Apr 6, 2009 | 09:07 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
i got it back on w/o that depresser. just push down hard and use a screw driver to set the clip in. doing that is run it around and it will click in.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
