engine casting # help?
Car: 1992 rs camaro
Engine: I think 350??????
Transmission: I think TH 350?????
Hello I think I am close can someone help? I have this info as my upper intake
6263751 72 350-175HP, 200HP, Corvette, Camaro, Chevelle, Monte Carlo, Nova CI, 7MV = My upper intake info ? My question is can it go on a 350 and a 305 block?
also
14010207 350 2 or 4 80-85 = this could be block info? but my block only has the 10207 not the full 14010207 is this the same thing?
14079261 350, 86 = this could be 350 head info?
this was on the inside of my valve cover on the head
DO I HAVE A 350 or a 305???????
Any help would be great
also
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: engine casting # help?
Heads and intake mean nothing to displacement since they can be installed on any engine. Based on the block casting number, it looks like you have a 350.
Car: 1992 rs camaro
thanks for your info I was unsure but that is what I thought as well. I know the enigine is not from the car so the cating by the water pump with the vin is to another car or truck. It also has a CE on the water pump mount plate is that a CRATE ENGINE resale or reman? If it is a CE it is hard to determine where its from right?
Car: 87 IROC L98
Pull the stamped numbers off the pad in front of the passenger side head.
Car: 1992 rs camaro
I di the pad has a CE which I found out could be a crate engine replacement or over the counter sell. Then it has the following numbers as well 4151895 and then this I think its the date code v1411frt. does that mean v= flint 04 =april 11-day and then FRT engine code but I can not find a FRT engine code at all? Some of the casting numbers are leading me to believe that is t a 305 and then some are like that of a 350? does this help?
junkcltr
Aug 2, 2019 11:12 PM
