code 32 and 12 intermitent check engine light
Old Feb 23, 2009 | 09:23 PM
89GTAFirebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Axle/Gears: stock
Checked the codes. Code 32 EGR and Code 12 Speed Sensor. Could the Speed sensor cause the code 32 since the EGR relies on the VSS to work properly????? And any idea which sensor the GTA has? The parts stores show 2 different ones. One at $65 and the other at double that. And the EGR... I just reassembled the top end and would hate to pull it back apart!! It runs very good. No driveability or idle problems which leads me to believe a VSS problem. And my speedo works fine all the time. So I am a little confused as to the actual problem. ECM ??? HELP...
Any help would be greatly appreciatted!
Thanks,
Doug
Old Feb 23, 2009 | 11:14 PM
Cuban-in-Camaro's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Transmission: rebuilt 700r4
Re: code 32 and 12 intermitent check engine light
read over this, about half way gets into sensors and what controls it. and i had that egr code set off last week, cleaned the everlivin out of it with brake cleaner and hasnt set off the code since then. http://sethirdgen.org/egr.htm
Old Feb 24, 2009 | 12:09 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
32 Egr - Also could be a vacuum leak. Check with carb cleaner engine will make a noticeable noise if you have one.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
