CAR RUNNING ROUGH. HElP?
Old Feb 25, 2009 | 12:49 AM
Camaroman575's Avatar
Car: 1988 Chevy Camaro
Engine: 305 V8
my 1988 camaro TBI is startin to run rough. i took off the air managment when i put headers on it. it has full new exhaust. i know the car is runnin a little leaner now that the air management is off. so maybe that could be a problem. i installed a rebulit racing 700r4 a year ago. has about 1000 miles on it. the engine has a little over 200,000 miles on it. nothing done to it. just oil changes, cap and rotor, e3 spark plugs and wires. idk why it is runnin rought all of a sudden. any advice would be good. please help.
Old Feb 25, 2009 | 12:57 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: CAR RUNNING ROUGH. HElP?
When you removed that did you plug all of the vacuum lines good? ALso make sure your firing order is correct, its really easy to swap a wire to the wrong spot and that will make it run rough.
Old Feb 25, 2009 | 12:02 PM
Engine: 305 V8
the wires are in the right spot. and i didn't have to plug any lines. it just all of a sudden started runnin rough when i was drivin
Old Feb 25, 2009 | 01:16 PM
10secondhopeful's Avatar
Car: '84 Z28
describe rough, it'll be easier to find the problem
Old Feb 27, 2009 | 12:50 AM
Engine: 305 V8
just started runnin rough. way less power. felt the engine runnin rough when i gave it throttle. i took of the rockers and took out the pushrods. none were bent or had flat tops. they were just corroded. could it be a valve? i heard a ticking noise so i thought it was a rod. but they seem fine.. i'm thinkin valves.
Old Feb 27, 2009 | 01:20 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Meh think i posted on your other thread Hows your Cat?
Old Feb 27, 2009 | 01:33 AM
Engine: 305 V8
its not the cat. have had my stock one go out and i know what that sounds and feels like. a potato gettin stuck inside lol. not the cat. valve maybe?
Old Feb 27, 2009 | 01:46 AM
ParkerTPIz's Avatar
did u do this b4 or after it was running rough? if u did this before, did u properly adjust the valves when u reinstalled all of the components under the valve cover? (just an idea)
Old Feb 27, 2009 | 08:51 AM
Engine: 305 V8
after
Old Feb 27, 2009 | 09:15 AM
ParkerTPIz's Avatar
ok , is it making any weird nose? or just running funny? does it sputter, stall or is it hard to start?
Old Feb 27, 2009 | 09:54 AM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
fuel pump and or fuel filter maybe going out...
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
